show auto-provision cloud-connector
Description
Displays Cloud Connector information.
Syntax Description
N/A.
Default
N/A.
Usage Guidelines
N/A.
The following command displays the Cloud Connector information for starting the Cloud Connector process.
Sample output for when the Cloud Connector process is not running:
      State                               Disabled
      Serial Number                       TR022320Q-40031
Sample output for when the Cloud Connector process is enabled and the Cloud Connector process is running:
      State                               Enabled
      Process                             NET TOOLS
      Active VR                           VR-Mgmt
      XIQ-SE Address                      10.139.12.70
Sample output for when the Cloud Connector process is enabled and the Cloud Connector process is not running:
      State                               Enabled
      Process                             None
      Serial Number                       PA062323G-00015
This command was first available in version 32.7.1.
Platform Availability
